Disables use of the switch's USB port.
| usb | Specifies USB port on switch. |
Enabled by default.
This command requires a reboot to take effect.
Stack support is not available. You need to run this command individually on each node in a stack.
Running unconfigure switch all removes this USB setting and returns to the default of enabled.
The following example disables use of the USB port:
disable switch usb This setting will take effect at the next system reboot.
This command was first available in ExtremeXOS 22.3.
